Toyota Calipers
I had reciently installed the toyota caliper upgrade on the front of my z but after bleading my brakes they still are real spongy. Has anyone encountered this while doing the upgrade?
Also, just to make sure is the bleed screw suppose to be at the top or the bottom. (just need verification) Kyle |
Re: Toyota Calipers
I did the same swap on my car; the bleed screws are on top. Did you replace the brake hoses? I hear steel braided lines will firm up brake feel.
Re: Toyota Calipers
Mine are really firm. Bleed screws on top, make sure you follow the correct bleed procedures.
Also, you can adjust the pedel height underneath the dash. Not sure if you are having problems with that as well. My suggestion is to bleed the brakes and the master cylinder some more. |
Re: Toyota Calipers
Yup I had them on upside down.
They work great now =) thanks Guys. Kyle |
Re: Toyota Calipers
guys, what kind of toyota caliber is good for my '81 zx? thanks
| All times are GMT -7. The time now is 02:59 AM. |
