Totaled hers, dented mine.
Old May 8, 2003 | 12:53 PM
auxilary's Avatar
the Dude
If I were you I'd take it to a shop to get an estimate done. Since your half shaft is toast, you can get a replacement from a junkyard relatively cheap, I'd assume.
The worse part is if your stub axle got damaged, and there is an inner and outer bearings for the stub axle. Unfortunately, all this ****'s expensive. The bearings alone with a seal will run you about 60 bucks. BCA makes good bearings, made in japan. You can order them from www.partsamerica.com. Double check to make sure everything spins freely without a lot of play, and without resistance. Watch for any grinding noise, and grease leaks.
To answer question about the camber adjustment - you can't adjust camber/toe/caster on the rear in stock form. You can cheat and slot the top strut mount holes, so the strut can slide about 1/2". that will net about .5* camber change max.
Satan's Aprntce
Jul 12, 2010 10:48 AM
KasbeKZ
Jan 21, 2009 06:36 AM
Z32GhOSt
Mar 19, 2006 12:08 PM
Zrolimit
Jun 4, 2005 08:40 PM
EatmyDust
Apr 18, 2005 07:26 PM
