THOSE WHEELS ADAPTERS
pls give me your 02 on wheel adapters,i need to know if i should put this on my z that way i can fit FWD wheels on my z.
is it safe and can i race with 'em,will it clear the toyota brake conversion?? pls let me know. thanx |
Re: THOSE WHEELS ADAPTERS
Jav a couple of posts ago was a discussion on adapters, and I think that should have the info you want. I don't see why the toyota calipers would not clear cause they are just spacers. ( width not hight)
What turns? There all straight to my Z |
OK,
1 more time -- As long as the centerline of the new wheel/tire combo stays in the same place as stock no additional stress is introduced. You are simply moving the web of the rim/wheel to the outside. Check your tread width (centerline tire to centerline tire) before and after the mmod. If it the same or close - NO sweat I have been running spacers for a while now - no problems. Actually they are not spacers - just lug adapters (4on 100mm) built with additional offset See mine on this site under "RIDES", then click on "79-83" then click on "gerryG" HIGHLY RECOMMENDED |
I have adapters on mine no problems and I run mine pretty hard. Ck my car out in the rides section.
Rick Old School Imports 4lyfe |
