Sway bar
Old Jan 14, 2002 | 09:07 PM
Julven's Avatar
Sway bar
What modifications are need to add the rear sway bar to a 70 Z? Have seen the welded brackets on the 280Zs. Does one have to weld/bolt on brackets? If so where do you attach the body mounting brackets?
5/70
pearl blue 240Z
SDiego
JB
garciaj@shiloh.navy.mil
blue 05/70 Z
Old Jan 18, 2002 | 06:48 AM
1tuffz's Avatar
Re: Sway bar
if your z has the factory tabs in place-but no bar [like my 73], you can use the factory location/tabs and do it yourself without welding-either to a factory size or aftermarket larger bar. you will need to get the hardware [tab and bolt with lock washer] that holds the bar into the locations forward of the lower control arms. you will also use the existing holes in the control arms themselves. i looked at an older 240 in a parts yard and used the hardware from it to upgrade mine.
hope this does the trick, it did for me.
David
1 Tuff Z, JCR supercharged
Z Car Club of Rochester
www.zccr.net
kirtdc
Jan 2, 2010 06:10 AM
terrasmak
May 24, 2007 07:04 PM
91zxtt
Jan 7, 2005 02:10 PM
xtasZ
Oct 27, 2004 10:27 PM
Blue280zxTurbo
Aug 24, 2004 05:01 PM
