Strut Mixing
I was thinking of putting the Tokico adjustables on the front cause I can get to them easily. And put tokico non adjustables in the rear. Does anyone know if this will work and how good. I will be running Eibach springs.
I would appreciate any and all imput. I will be using my Z for road racing and some light AutoX Shane Morton 78 280Z owner. Z me go - Z me show - Z me gone |
Re: Strut Mixing
hey dude I've seen a coilover set thats easy and very cheap and hey it works well . it consists of the lower spring seat released from the strut (just the tack joins cut) and a long sleeve (pipe)that that sit over the strut and lightly welded on the strut at each end AND OH the pipe is threaded as in plumbing steel pipe from top to bottom (same as a coilover)
a big nut (for locking the) other say 2.5 inch long other big bolt which has the coil seat welded to it at one end of it. can you see how this looks like a $15 coilover combo . it works and its great for full adjustability of suspension. Ive seen it on a 800HP DRAG 240Z street legal baby. |
Re: Strut Mixing
That setup sounds great! just make sure that you adjust the fronts after you start driving it to balance as well as you can with the backs and it should be great!
The Beast is back and badder than ever! |
