spark plugs
hey guys, Im looking to replac my plugs, and I was thinking about getting bosch super four plugs. these are the one with the four points instead of the tradtional one. I've spoke to a couple of friends who run these in their engines (most of them are toyota 4AGE engines) , and have gotten mixed reviews. One said he lost a a bit of top end power. is this possible? Should I change to these, or should I just run the normal plugs?
Kolts Perth - Western Australia |
Re: spark plugs
I've always been told that NGK is the best brand to run in a Z
Jamie Shelly kd5izq@msn.com ICQ - 159705433 IZCC Number is #12402 |
Re: spark plugs
From experience I used to use Bosch Platinum plugs, then I tried split fire an know I use NGK BPR6ES-11 I noticed that my car runs better with this plugs. I have more power. Split fire did not work for me. and Bosch are alright but there is more puch and low end torque with NGK. They also have platinum plugs, but I have not tried them I will next time I change the plugs. I will order them through checkers auto parts. www.cskauto.com I almost forgot I used the Bosch 4+ and they worked the same as the regular platinum. I did not feel a difference either on power or gas mileage. At the end is your call. all this is from my experience. good luck and hope this helps.
"It can't rain all the time" |
