sons first car is a 77' 280z and has a few problems and need advise and HELP
Old Jun 20, 2011 | 11:34 AM
scrapyard2011's Avatar
need help with 77 280z
When i push gas it goes up to 2300rpms and dies out. no matter if push slow or fast same results.Changed filters,plugs,and air intake censor.Any ideas
Old Jun 20, 2011 | 08:25 PM
When i push gas it goes up to 2300rpms and dies out. no matter if push slow or fast same results.Changed filters,plugs,mass air flow.Any ideas please i need help he wants car to run soon
Old Jun 20, 2011 | 08:56 PM
You "changed" the mass air flow? (It's actually an Air Flow Meter). The usual culprit of that ~2k rpm stumble is water in the TPS, way off timing, or mis-ajusted AFM.
I would try unplugging the TPS (throttle position sensor) and see what it does.
Old Jun 20, 2011 | 09:45 PM
NismoPick thats wat i ment my bad anyways thanks for the advise ill try it tomorrow
Old Jun 21, 2011 | 05:48 AM
blue's Avatar
The TVS on the side of the throttle body is probably shorted. Unplug it for a quick test. If it works unplugged then that is your problem. Some also call it TPS.
Read this: http://atlanticz.ca/zclub/techtips/tps/index.html
zdrifter91
Feb 20, 2014 12:14 PM
PowerhungryBill
Oct 13, 2005 07:24 PM
aaron-san
Oct 4, 2005 02:21 PM
Redneck280z
Mar 24, 2003 06:27 PM
