Skyline swap?
Old Nov 9, 2002 | 09:05 AM
auxilary's Avatar
the Dude
Re: Skyline swap?
depends which skyline. engine wize, rb20det from the r32 gts-t, and the rb25det from r33-4 gts-t are almost a direct bolt in. you'd only have to procure 200zr motor mounts (that's a 300zx z31 with the rb20det motor commonly found in japan and australia), that as I understand, bolt up directly to stock mounting locations.
And if you want detailed info on RB26dett motor swap (skyline gt-r), you can find it here:
HybridZ link
Other things to include in the swap would have to be either a pressurized tank, or an external high rate electric fuel pump, custom drive shaft, custom tranny crossmember, wiring harness (you could use one out of a skyline), air/fuel and boost management, cooling system, etc
'73 240z
'99 neon R/T
Mammon
Jun 17, 2014 04:15 PM
90PearlZ
May 25, 2007 07:31 AM
matts81zx
Aug 21, 2003 09:25 PM
george
Mar 14, 2002 11:06 AM
eurozx
May 21, 2001 08:26 PM
