Rims...
Re: Rims...
Your bolt patten is 4x113, offset should be 0. biggest wheels as in width, or size? biggest tire size you could do would be 225s on stock suspension if memory serves me correctly.
If I'm wrong, someone correct me.
Guest
Posts: n/a
Re: Rims...
I've seen 17" wheels on Z cars before, but this was usually a wheel with a different offset and bolt pattern than stock so they had to use an adapter. However MSA does sell 16" and 17" wheels with the proper bolt pattern and offset, but the style choices are limited. If want modern style wheels you have to use an adapter. See the Z Driver project 240Z for an example.
Joey
1976 280Z 2+2
2+2s are not ugly
Joey
1976 280Z 2+2
2+2s are not ugly
Guest
Posts: n/a
Re: Rims...
I run 17 X 7 Tenzo-R wheels. I also have 215/45/17 Toyo Proxies tires. They don't rub, as a matter of fact - the dia. is the same - so no speedo changes are required
The challenge is to keep the weight of the wheel/tire down. select only light rims. The salesmen don't want to give out the wheel weights but if yiou press them you can get it
LOL
you can see mine at
https://www.zdriver.com/rides/detail...x=16&vehId=109
<P ID="edit"><FONT class="small"><EM>Edited by gerryG on 05/30/02 04:05 AM.</EM></FONT></P>
LOL
you can see mine at
Re: Rims...
i am running 17x8.5 wheels with yokohama 205/40zr17's. i also have coilovers. with this combo-no rubbing and i have about 1/2" clearance both front and back side of tires [to fender and strut]. mine are compomotive wheels from motorsport specialties. -www.usacomp.com
David
1TuffZ
zccr.net
David
1TuffZ
zccr.net
SandW
Oct 31, 2006 09:26 PM
