Replacement Fuel pump 280Z 77 ? Recommend Any
Hello
RE: 1977 280Z Just blew my 3rd STOCK Fuel pump in as many years...Any other models Recommended as the stock just doesn't hold up. Please brands and model numbers please. Cheers The Forgotten Rebel P.S Runnin 12.5:1 Compression, Big throatTB, headers, Race cam, Blue printed n balanced, Lite flywheel, 4:11 R200 LSD, port n polished, Matched intake, K&N filter, Crane coil, Turbo injectors & Turbo AFM,Toyota brake up grade, Short shifter kit, Reads average 270 for all 6 on Compression test...Ya get the picture. And a hell of alot more that i forget ! |
Re: Replacement Fuel pump 280Z 77 ? Recommend Any
what's your fuel pressure? If you run the fuel pressure high all the time, you can shorten the fuel pump life. I would go with turbo pump or 911 turbo pump.
