Repairing Lady. (74 260z)
Old Feb 6, 2008 | 05:42 PM
JPerkins's Avatar
This thread is to adress the issues and concerns pretaining to the repair and restore of my 74 260z as opposed to creating a new thread everytime something comes up.
Current issues:
Wiring problem resolved (somewhat) - front side markers were grounding out to the body. they are disconnected until I get them either repaired or replaced. Under dash wiring is still a nightmare to me, but its working, so i will leave that particular part of it alone for now.
Differential clunk - its been too cold to work on it so this issue hasn't been adressed at all yet.
My body kit was liquid nailed to the car - this stuff is a Bee-otch to get off. i've had to come at it with a hammer and chisel and its still really slow going. might just be the cold weather. i'm trying to get it off in one piece, so busting it isn't an option. (yet)
No choke cable - its just hard to start in the mornings and it idles high when its warm.
Engine misses on accelleration - i believe this is due to a bad spark plug wire. Investigation in progress.
Needs interior door panels - Meh, its just a broken cosmetic part that needs to be replaced.
Weeps coolant from the engine block - like that when i got it. Dunno what it is yet. looking into it.
Oil in the coolant reservior - I am not liking this little issue at all. Don't really know what it means yet, but I DO know that oil does NOT go there.
Old Feb 6, 2008 | 06:17 PM
KasbeKZ's Avatar
Pr0n Addict
i don't know what kind of feed back you are looking for but here a re a few of my oppinions:
diff clunk is certainlly hard to fix. i'd just look for a new one
liquid nail is going to make paint under there look terrible. i'd be ready to repaint if i took all that off.
oil in the coolant and loss of coolant = blown head gasket. long job but low parts cost
no choke cable: there should be provisions for one, so it's easy enough to make one or get the one that is supposed to go there
Old Feb 6, 2008 | 06:41 PM
JPerkins's Avatar
repaint is definately on the to do list already. the rust damage and body dents already dictate that much.
the blown headgasket thing is good to know.
As far as desired feedback, that first message was kind of a "heres where i am right now" message. Any and all feedback is welcome.
Old Feb 6, 2008 | 06:48 PM
KasbeKZ's Avatar
Pr0n Addict
good luck with the re-paint and head gasket change! it's not that hard, and it gives you a good opp to do a lot of other little maintenance-like things.
Old Feb 6, 2008 | 07:14 PM
usuallly you get coolant in the oil, not the other way around. lol. check yer oil. also, the rear clunk is more than likely actually just a bushing. its a werrr or a whine you have to worry about. teh clunk could also be a U joint. the car will prolly need paint any who, but good luck with that liquid nails lol.
Old Feb 6, 2008 | 07:25 PM
theramz's Avatar
I have a present for you...
Empty the coolant reservoir and see if it is motor oil or just old coolant. Check in the radiator for oil and while it's running look in there for bubbles. Bubbles mean leaking compression, oil can be a crack in the head or block. Check your engine oil for coolant. Missing under aceleration can be caused by a lot of things. Fouled plug from bad head gasket, bad wires, dizzy cap, rotor, carb adjustment. There is alot you can do yourself to save$ but if you don't have the tools or work space you should find someone to help you.
Try a heat gun to soften the glue, most glue fails at 350 degrees but so does paint. Try it by heating the panel not the metal while pushing a putty knife between. Take your time, the paint is not going to survive anyway. Search this and other forums for advice on the diff clunk. Be happy, now you have something to do on the weekends. It's called a hobby, never ends!
Old Feb 6, 2008 | 07:28 PM
KasbeKZ's Avatar
Pr0n Addict
true story on the u-joint. so yes, check your oil to see if it's got white foam in it. i have seen oil in the coolent a few times. it can happen, but just comparing the pressures of the two passages suggests that it will usually happen as snw said
Old Feb 6, 2008 | 09:53 PM
check the compression to while your at it, they also have a testor kit for BHG that you use a sample of radiator fluid your using and it will let you know if your getting contaminants in it from a BHG.
Old Feb 7, 2008 | 05:08 PM
JPerkins's Avatar
Got the rear bumper/body-kit off in one peice. hammer and scraper. paint is f##ked. but i saw that comeing. didn't see the gigantic globs of rubber cement/liquid nail that would be stuck to the body undernieth it though. Other than that, the body looks good. only one little spot of surface rust on the rear end. Next will be the side skirts.
Old Feb 8, 2008 | 05:39 PM
Sweets's Avatar
Usedta be Justin260z
Are you sure its oil in the coolant? Where are you getting your coolant samples from?
I'll be happy to take that body kit off your hands if you dont have any other plans for it!
Old Feb 8, 2008 | 05:57 PM
^^^^ there's the con-artist now !!! GET EM'!!! lol just razzin yah
Old Feb 9, 2008 | 09:27 PM
JPerkins's Avatar
haha, i talked to Mr.Bobby. Turns out theres not a damn thing wrong with my headgasket. Justin, remember when the auto tranny f-ed up and it got swapped for the five speed? it had an auto radiator and the tranny oil and coolant basically just ended up swapping places, now theres just a continuous oil residue in the radiator that won't go away. thats all it was. And turns out Mr.Bobby knows Lady pretty damn well. Hes even got the door panels that match the fabric of the seats in it right now. Dunno if i'm gonna like that too much, but its better than the ripped passenger panel thats in there right now. hes also got the front fenders to replace the f-ed up one. and get this. its offa the same car you got the hood off of, and the seats from too. Figured i was gonna sneek one by him and get a z that he'd never seen before. little did I know that he was the one to provide a good chunk of the parts currently in use on Lady.
On the body kit, i'm keeping it for now. Gotta clean up the liquid nail and such, then move from there. One step at a time gentlemen. got the rear section and sideskirts off, and the front is just bolt on, so its pretty much loose now. next comes the cleaning and patching process, then the painting. Money, time, and effort. heh, the only one i have in droves is effort.
Old Feb 9, 2008 | 10:25 PM
the front kit is nice, i would keep it. and i like the 2 tone black front and hood, and red else where, idk y but it looks nice. also, its all a fabric right? like the door panels and seats? you can dye that stuff any color you want.
Old Feb 9, 2008 | 10:42 PM
Sweets's Avatar
1. the hood is off a junkyard car
2. it was never an auto, it was a 4 speed
3. the seats are custom
4. I know for a fact it doesnt have an auto radiator
Old Feb 9, 2008 | 10:48 PM
JPerkins's Avatar
*scritch scritch*.......hmm..well, maybe hes thinkin a different car or he knew it before you ended up with it. I dunno. In anycase, hes a good parts supplier.
Old Feb 9, 2008 | 10:49 PM
Sweets's Avatar
Thats for sure. Hes got enough parts for all of us!
Old Feb 9, 2008 | 11:16 PM
JPerkins's Avatar
if i was still FI i'da tried to talk him outta the N42 mani he had ported and polished and powdercoated up in race trim.
Old Feb 10, 2008 | 12:41 AM
OOGA BOOGA!!!! whats up with the S13 in your sig? just a stock DD SOHC 2.4 litre? you need to SR that bitoch and go kouki on its ***!!!!
Old Feb 10, 2008 | 08:57 AM
JPerkins's Avatar
happen to know how to remove the rear bumper struts? looks like they've been cut off to accomodate the rear body kit, but how do you remove them from the body?
Old Feb 10, 2008 | 10:06 AM
Sweets's Avatar
Not a clue how to remove those
Snw, that s13 is my wifes car. Its a stock single auto. We have big plans for that one!
Old Feb 10, 2008 | 10:42 AM
Dude... where's your Haynes manual??? It should be just like the S130's.... one bolt on the floor of the hatch area.
Old Feb 10, 2008 | 12:08 PM
JPerkins's Avatar
heh....left out in the rain during the last cold snap. Remembered to grab all my tools, but the manual got left on top of the car. Its now a haynes paper brick. i got another one on order. should be here either tomorrow or tuesday.
Edit: just checked out what you said nismo. Can't get the passenger one out without droppin the gas tank. Damn. oh well. Time to drop the tank.
Old Feb 10, 2008 | 12:13 PM
raythenegr0's Avatar
Poor kid, no ruler
Give me a sec, gonna try to find the camera and upload the pages.
Old Feb 10, 2008 | 12:24 PM
Poor kid, no ruler
Scratch that, can't find it. I'll write it out for you.
1) Remove the side bumper plug, then remove the two bolts retaining the rear side bumper to the car body.
2) Remove the two nuts retaining the bumper to the shock absorber and remove the bumper assembly.
3) To remove the shock absorbers the fuel tank and muffler will have to be removed. Te shock absorbers are removed by removing the retaining bolts and nuts.
4) Installation is in reverse order.
Old Feb 12, 2008 | 08:07 PM
JPerkins's Avatar
Additional issue:
Brakes - a whole lot of pedal travel with NO response, and then almost full response in the last quarter of pedal travel. car WILL STOP. its just not pretty.
