ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   Rear wheel alignment (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/rear-wheel-alignment-596/)
Naiem Jul 20, 2001 02:01 PM
I have an '82zx 2+2. I just had the rear wheel alignment checked and both the toe and camber are way off on the right, the left is perfect. The problem is that there seems to be no adjustment for either toe or camber. Can anyone suggest a solution.
Thanx.
ZmeFly Sep 3, 2001 04:08 PM
Re: Rear wheel alignment
alignments are what i do and there should be a shim adjustment its a piece of material that sits behind the drum to move it into alignment. check to make sure that they have that available to you. it should be i will check tommorow when i go to work.
watch out here comes my Z V8 powered and ready to roar
