RB30 ENGINE IN A 260z
does anyone know what i would need to do to get an RB30 ENGINE in my 260z? what would i need to do to fit it in? do i have to get a new trans and all ? Any advice is appreciated
Re: RB30 ENGINE IN A 260z
Is that an old 'Creations' manifold on your car?. I've got one just like it, well apart from the custom plenum & aluminised coating...
Anyhow, yes you will need the RB gearbox & mounts & a modified sump, and lots of other things. My dad's in the process of putting an RB25DE into one of our 240Z's but the actual fitting of the engine is quite a way off yet. Which capital city are you nearest to? Ben Adelaide, South Australia |
I have a rb26 in mine. the block is the same just a little taller. you can either custom make all mounts and driveshaft or you can use rb-20 eng mounts from the Z-31 (japan spec) use teh r-33 gtst tranny and front 1/2 of the driveshaft and the only mount you have to make is the tranny mount.
If you use a rb25 grab the oil pickup and pan from the z-31 rb20 and it is a bolt in mod!!!! Ive been told austrailia didnt get the rb20 z-31 so that may be a problem. my 2 cents 7796-engideling.jpg |
Seen it done - a guy in Melb has a white 260Z 2+2 with an RB30. Apparently not to difficult a swap.
Are you going to use the turbo motor? |
My friend has an RB30 turbo in his 240Z its a tight fit and requires a few modifications but it goes really hard...
Still waiting on my RB20DET :( |
I've never seen a turbocharged,carburetor set up in a Z before, that's pretty wierd looking. Also just curious, why are there so many Aussies on this board? Is it based in Australia?
Joey 1976 280Z 2+2 2+2s are not ugly |
its based in america... but we aussies just love our Z's
<font color=blue>76 260z</font color=blue> The NiteRider |
lo
again testing i finaly got my profile to work keep it realZ |
would the RB20 engine mounts from a Skyline work??
Gavin, Melbourne Australia 73' Datsun 240z |
I don't think so - the 200ZR has a different x-member & mounts & they're the ones you need. Perhaps the Laurel or Stagea mounts would work, but your guess is as good as mine.
Not that it's critical here in AUS - I could list 1/2 dozen workshops in each city that could fit an RB to a Z. There's plenty of local knowledge here. Ben Adelaide, South Australia |
IF your going to sell ur turbo setup when u put in a RB, i"ll buy it from ya...
If you did that, I'd STRONGLY recommend the use of a TBI setup over the carbs. Perhaps something like a single 45DCOE-style throttle body unit with big injectors.
Converting one of the 'creations' manifolds to MPI is a pain (been there, done that)... Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20DET DR30 Skyline RS-X |
What is the RB30 engine out of and is it a potentaly better motor than the L28???
Rb30 is out a a holden vl commodore, and the R31 skyline, the RB is the better version of the L28...
Rb's are out of skylines <font color=blue>76 260z</font color=blue> The NiteRider |
| All times are GMT -7. The time now is 07:07 AM. |
