RB26DETT in Z
Old Nov 30, 2002 | 12:10 AM
auxilary's Avatar
the Dude
Re: RB26DETT in Z
http://www.hybridz.org/ubb/ultimateb...;f=15;t=000125
why a single turbo? i don't see an advantage of a single turbo on an rb motor since they're not sequential turbos. you have a turbo per bank of 3, not a smaller turbo spooling the bigger one
'73 240z
'99 neon R/T
Old Nov 30, 2002 | 09:19 AM
auxilary's Avatar
the Dude
Re: RB26DETT in Z
uhm... how exactly are you planning on using the GT-R transmission? Are you converting your Z to awd?
'73 240z
'99 neon R/T
Old Nov 30, 2002 | 02:27 PM
auxilary's Avatar
the Dude
Re: RB26DETT in Z
a lot
'73 240z
'99 neon R/T
Old Dec 1, 2002 | 09:14 AM
auxilary's Avatar
the Dude
Re: RB26DETT in Z
hope you have deep pockets. you'll need to build up the bottom end, so plan to fork over a lot of money for parts not regularly available in the united states, like pistons, crankshaft, bearings, rocks, etc. What kind of a rear end can reliably handle that sort of power? Ford 9", but I doubt you'd be converting to a live axle. You're also living a pipe dream when you say the following in the same sentence:
"I want it to make 750rwhp, i want it reliable, and I want it to be streetable." You can make it reliable and streetable, or you can make it have 750hp. Pick 1. You realize that you're talking about making 863 hp at the crank with an estimated 15% drive train loss?
Let's discuss parts:
-rb26dett motor is about 3k
-gts-t rwd transmission -1.5k (note, these are just random numbers i'm throwing here because they'll likely be more costly when they're not a combo package)
-flywheel and clutch to handle the said power - 1k
-injectors and bigger turbos - 3k
-haltech system management - 1k
look, i haven't even gone through half the items, and parts alone are costing you almost 10k.
-rear differential... you could use an r230 from a 300zx tt. $500 used
-intercooler - 1k
-suspension and brakes to handle this - 3k
-custom transmission and motor mounts
-custom piping
-custom done exhaust
-sump, pickup and oilpan to cut and shave from a 200zr/r32 skyline gts
-rear stub axle to cv conversion for r230 rear diff
-new fuel lines because stock are not big enough to supply fuel
-new fuel tank
-fuel pump
-rollcage
-frame rails and chassis stiffening
and a lot of other custom work that's not coming to mind right now.
See what I mean now? Unless you have deep pockets and plan to do all the work yourself, including building up the engine, this is a very long and tedious project. Especially if you don't know what you're doing
'73 240z
'99 neon R/T
distanceZX
Feb 4, 2013 11:35 AM
Ratfink
Dec 10, 2007 11:00 PM
dustin_ra
Mar 28, 2007 07:03 AM
pete8717
Nov 7, 2005 08:06 AM
GodZilla
Apr 13, 2001 07:39 AM
