R200 limited slip differential
Are any of the stock R200 rear difs limited slip? Can you use one from another model of Nissan?
Re: R200 limited slip differential
the answer to both questions is yes. some good ones are the 88 turbo rear, the very nice ifiniti Q45 rear.
watch out here comes my Z V8 powered and ready to roar |
Are the R200 diffs that everyone goes on about found on Z31's? If so how hard are they to get and how much do you think one would set me back?? Do they need special machining to match up to the drive shaft? One more thing what ratio are they?
-=240z=- |
Hiya guys,
The LSD is the holy grail for me kind of;) alright the R200 stock LSD you are looking for is from a 1987-1989 300ZX turbo, It has a finned covered and will fit into the Z, but you have to use the normal R200 diff cover. There is a 1988 300ZXT special edition which is a less desirable to grab because its a VLSD and is hard to swap, but still can be done there is a swap article on 240Zturbo's page. hope that info helps zya Yuichi Zdriver.com |
