problem
Old Apr 16, 2002 | 03:48 PM
zguy36's Avatar
Dead
problem
I've been trying to get my car to run well, but it just doesn't seem to be going in my favor. It has an '83 turbo motor (specs in my profile). With boost, it won't rev over 5000 and totally falls on its face, backfiring out the exhaust and surging like crazy. I've checked fuel pressure, changed plugs, plug wires. All of that stuff is good. Do you guys have any more ideas? Thanks.
-jeremy-
Old Apr 17, 2002 | 12:29 PM
lifegrddude's Avatar
Externally Wastegated
Re: problem
I looked at your specs, but didn't see anything related to fuel delivery. Are you running the stock injectors and pump? If so, you might be experiencing fuel cutoff. Maybe the injectors hit static op. How's the fuel filter? Clogged? I can't think of much else since I'm no expert, but those are some suggestions you can look at. Good luck finding the problem.
82ZXT
Old Apr 17, 2002 | 07:53 PM
zguy36's Avatar
Dead
Re: problem
fuel pressure stays high, air cleaner is new and large
-jeremy-
Old Apr 19, 2002 | 01:02 PM
Re: problem
First of all, your intercooler isn't big enough!
hehe... but really, it does sound like fuel is leaning out. How much boost are you running at 5000 rpm? You should replace the fuel filter and maybe have the injectors professionaly cleaned. (they disconnect the fuel rail and run straight cleanering through your engine) And maybe turn the boost down a little just to see if the engine runs smoother all they way up.
Old Apr 19, 2002 | 03:52 PM
zguy36's Avatar
Dead
Re: problem
I've been thinking about this problem for a bit and think I may have come up with something. When I am running 20 psi boost and rev over 5000, it falls on its face and runs bad afterwards for a minute or two. This sounds almost like floating valves! Maybe with that much boost pressure, the boost is holding the intake valves open making it lose power, then the lifters pump up making it run bad afterwards. Anyone had this problem?? This also explains why it doesn't do it with lower boost.
-jeremy-
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
