power steering
I did some research and all I could find was that you could use power steering components from a mustang (forgot which year). Are there any other options? I want power steering, but don't want too complicated of a swap. the mustang swap includes quite a bit of work and stuff.
A few years ago I used to align semi-trucks. Try taking your car to a good alignment shop and tell them what you want.
I had a driver come in to my shop and the ugly old freight shaker was so hard to turn you darn near need 2 people to steer at low speeds. I lightened up the steering and you could "Almost" turn the wheel with your finger. Now I realize that a Z and a Peterbilt, Kenworth, Freightliner etc. are different animals, but it might work and save you a ton of time and cash. Just a thought... Alignment techs. can work wonders when they want to or have the skills. Luckly I was trained by the manufactuer and knew my stuff. Chris |
what did you do to lighten up the steering? Are these possible DIY type jobs for a somewhat mechanically competent guy with very competent friends?
Chris |
try putting more air in your tires, if your pressure is low it is really hard to turn. when I first drove my z around the nehiborhood w/ the old cracked tires that I did not want to put too much air into them, when I put the new tires on at 36 psi. it drove like a dream
No Power Steering, its a drag..
I agree with all those above, power steering should not be needed on a car that weighs little more than 200 pounds...
make sure the tires are good sized, and well inflated.. i try to keep about 36# all around. get it aligned, it shouldn't be too expensive, and try it out. If all else fails, drive it around for a few months. By that time, you will be used to driving it. |
| All times are GMT -7. The time now is 11:13 PM. |
