no oil press.on 240
1971 240z
eng rebuilt. new bearings, rings etc. started engine...0 oil press. installed new oil pump. removed dist and shaft and used a drill and driver to prime pump. installed a mech oil press gauge in eng comp. ran drill for several minutes and still had 0 oil press on mech oil press ga. removed valve cover and ran drill. oil is oozing out of cam shaft. any thoughts on where or what the problem is? help |
Did you first fill the oil pump & oil filter? You'll probably never get pressure w/o priming them first:
https://www.zdriver.com/forums/showt...ime#post280013 |
| All times are GMT -7. The time now is 03:04 AM. |
