No brake pressure
Sorry to be that guy but I've run into another issue with my brakes. Now everything has been replaced, the metal breaklines, connectors, brake booster and master, ect. all new, however my front lines are dry, bone dry and the reservoir is not dropping any, there are no kinks or links in the brake lines but can't figure why it's not flowing. The rears have brake fluid gushing out just fine but I'm not getting any flow to the fronts, any ideas?
You need to bleed the system.......
Of course
I've bled it repeatedly but I'm not getting any flow out of the fronts, only the rears.
bleed the master
if you would really like answers that would help you and avoid flames give the following info when you post: year of car, n/a or turbo engine, stick or slushbox, digital or analog dash. Most of us can tell by the year what model you have ie 85T is a turbo z31. Z cars come in many flavors and they are all different. example 84,85,86 Z31's pretty comparable. there were changes in 87,88,89. in addition 300ZX can refer to two completly different cars the Z31 and the Z32. No mindreaders here the more info you can post the more likely you get a cogent useful answer. The cars with L engine (straight six) changed almost yearly from their introduction. A 240Z and and a 280Z have similarities but they can also have wide variance. |
Originally Posted by rogerz
(Post 342295)
bleed the master
