My door doesnt stay locked? wtf?
So like the title says. I cannot lock either of my doors from the inside. It will only lock when I use the key in the door. On the driver side.. when I lock it, you see the door nub thing go down 90% of way but u don't hear the click. When you try the outside door handle it is locked.
Or so I thought... If I pull the handle all the way to the top, (higher then you need to lift it when the car is unlocked) the little door nub inside pops up and the door unlocks! It only does this on the driver door. So it appears locked, but if you pull it high enough anyone can open my door. Any suggestions?
