My Defrost doesn't work
Old Nov 18, 2002 | 02:56 PM
Re: My Defrost doesn't work
What year car do you have?
Is it the fan motor that is not turning on, or is it that your air flows out the vents toward you and not up at the windshield where you want it?
If it is a 75-78 Z, most likely there is an air leak. Those cars have a large plastic canister in front of the battery. That canister holds air vaccumme and pulls some levers to aim air up at the ducts for defrost. Mine had an old hose that was leaking. Replacing the air hose to that canister fixed the problem.
Old Nov 19, 2002 | 08:11 AM
The hose is generic. You can buy a small reel of hose. I think its the same size of hose for the vaccume advance on your distributor.
As for the lever not moving all the way, please do open up your dash. You just need to take out the lower part, not the actual dashboard. One of those levers might be bent from someone forcing it or the cables might need some lubrication. You'll be so happy once it is all working smoothly.
todd5854
Jun 30, 2024 11:32 PM
swlabr
Feb 7, 2014 06:59 PM
Turbo86
Apr 25, 2006 03:13 PM
albow2213
Aug 3, 2002 08:56 PM
84turboz
Apr 24, 2002 06:55 AM
