Mass Air Flow
Dose anyone know if there is an after market performance MAF for a 76' and where to find it.
76' 280Z when the guy in the rice sees you grin he'll find out why at the line |
Re: Mass Air Flow
Well, 76 isn't mass air so you would have to switch everything to be able to use mass air. And, no I don't think there is any performance replacement for 76
Re: Mass Air Flow
Yes it is 76' is the 1st year of the bosch fuel injection mass air is on the car. I work on cars everyday and i know what mass air is. not tryin the be cocky about it but i know what i'm talking about.
Re: Mass Air Flow
You mean air flow meter? That's what come in 76. First year was 75. It's L-Jetronic no Lamba. Mass air came on 84 on 300zx. I think you got your terms mixed-up.
Re: Mass Air Flow
Yup, it doesn't use a mass air flow meter. A mass air flow doesn't use the flap. That is called a vane air flow meter.
-jeremy- |
Re: Mass Air Flow
i don't really care what its call basicly the same consept and it was stated like so in the haynes book for the car all i ask is that my question is awnsered.
Re: Mass Air Flow
There isn't performance upgrade out there that I know of. But you can do couple thing to make yours better. one is to loosen the coil spring by one or two notch inside to make the AFM(air flow meter) react quicker.( also makes mixture little bit more rich) Secong is to replaces the outside shell with turbo AFM. You wouls have to use the N/A (normal aspiraration) guts to make it work with your 76 ECU. You would need an air fuel ratio gauge to get a proper setting for best result.
