Lug pattern for 240z help please
Guest
Posts: n/a
hey guys i have a guy who wants to sell me a set of konig imagines the lug pattern is 4x114.3 Will they fit my z car? Or what would i need to do to make them fit. they are 17x7's, they came of a biger lug style honda.
well first off they are thr wrong bolt pattern and second they might also be the wrong offset.. the Z bolt pattern i think are 4x100 and our offset is "0". the honda offsets are from 38mm to 42mm you might have to get spacers for them.. good place to get them are from modern-motorsports.com they can sell you the spacers your going to need to fit them on your Z
Guest
Posts: n/a
114.3 x 4 or 4.5" x 4 is the correct pattern.
the offset is what really matters
it's the imaginary centerline thru the wheel, kinda like slicing it like a bagel.
the center is zer0 (what Z's take !)
towards the streetside is a positive offset. front wheel drives normally have +40 plus or minus some.
with a stock or upgraded suspension this will not fit with a hacksaw & a spacer ! Chainsaw doesn't make clean cuts, or just plan to make real wide turns.
Spacer is a whole different story
ALTHOUGH !
Motorsport has somehow found a combo with the Konig Imagine that fits.
Konig still doesn't agree that they fit, but what do they know.
call motorsport.
ALTHOUGH !
call motorsport.
Guest
Posts: n/a
with coil overs i've seen guys running 18s without flares. check out www.modern-motorsports.com if you are looking for options. Ross also carries honda wheel adapters.
BirminghamHokie
Feb 18, 2014 07:34 AM
Graham_Creager
Jul 19, 2004 04:36 AM
