lowering a z
Old Oct 29, 2002 | 08:49 PM
auxilary's Avatar
the Dude
Re: lowering a z
ground control
carrera suspensions
zdatsun.com
arizonazcar.com
motorsport auto
'73 240z
'99 neon R/T
Old Oct 29, 2002 | 09:00 PM
Spudz's Avatar
Re: lowering a z
Up to about an 1" you should be okay after that then you
need to start thinking about camber and sectioning your
struts to allow full travel of the shock insert. I am about to
put on coil overs, and camber plates to lower my car.
The car is currently lowered 1" with a spring change.
Auxilary listed a few places that carry coil over kits for the
Z, and I have a few more he missed including the web site
sponsor www.strictlyz.com they can get you the
Ground Control set up .
Old Oct 29, 2002 | 09:01 PM
auxilary's Avatar
the Dude
Re: lowering a z
he's referring to camber plates
brief explanation of suspension geometry:
camber - your tire's top is either angled in towards the car, or away. towards - negative camber, away - positive.
/ / <--neg camber
\ \ <- pos. camber
toe - which way your tire points. toe in - tires are angled towards each other. toe out - the tires are angled away:
/ \ <--toe in.
\ / <--toe out
caster - how much your strut is angled to the wheel. positive caster means the strut is angled more towards the back of the car. (front relation)
Now, when you lower a car, your control arm retains the same position, but the strut on which the spring sits becomes angled more towards the body. The wheel, which is mounted to the hub that is part of the strut assembly, becomes angled in towards the top, therefore giving the car more negative camber. a camber plate corrects that by allowing the user adjustability to reposition the top of the strut to restore proper camber.
'73 240z
'99 neon R/T
Old Oct 29, 2002 | 09:02 PM
auxilary's Avatar
the Dude
Re: lowering a z
sorry dude, it's late, i forgot about kyle and yuichi, plus i spent some time typing up the explanation above
'73 240z
'99 neon R/T
Old Oct 29, 2002 | 09:09 PM
Spudz's Avatar
Re: lowering a z
LOL ..... Yeah and I totally missed the original question
being camber plates [img]/w3timages/icons/smile.gif[/img] . I will be using EMI racing
camber plates on my car front and rear.
Old Oct 29, 2002 | 09:35 PM
auxilary's Avatar
the Dude
Re: lowering a z
I won't be using camber plates - i'll be using adjustable control arms with heim joints and adjustable t/c rods.
'73 240z
'99 neon R/T
sticky280zx
Nov 16, 2007 07:30 PM
tsefreeflow
Jan 11, 2004 07:23 AM
cwd240z
Aug 20, 2002 10:16 AM
85_2fast4u
Jun 27, 2002 10:16 PM
jason
Jun 6, 2001 07:27 AM
