Looking to conver to 4.6 ford
has anybody done the research on which ford 4.6 engine is best for the 280z. I have seen several different versions for sale on ebay and other sources. I doubt that I will afford the dohc option so that one I am not to interested in.
will the crown vics and truck engines be the same as the mustangs?
do I need to find an engine that had a manual tranny if I want to end up that way in the end?
Any years better than others?
Your probably needing to go to hybridz.org
They're more into swaps than most people here.
Don't get me wrong you can find some answers here,but most of your questions can probably be answered at hybridz.org gl with your swap man.
I was thinking of that swap too. I measured the Crown Vic. It will clear the inner fenders but you might have to drill holes to access the spark plugs. I think the 4.6 single overhead cam will fit a lot better but they are still a little pricey. The 5.0 mustang engines (roller cam)are plentiful and are a lot less expensive to get 400hp with just bolt ons. The explorer V8 has the iron gt-40 heads with the bigger valves.
Originally Posted by theramz
It will clear the inner fenders but you might have to drill holes to access the spark plugs...
The spark plugs are on top of the head, near the intake manifold.
