late '74 260z coupe floor pan dimensions
Looking for basic dimensions for the floor pans on late model 1974 260z coupe. Getting thicker metal cut at a steel supplier and I need basic dimensions. I would measure mine but for replace pans, I'm not entirely sure what qualifies as the end of the pan and beginning of the firewall since it kinda slopes up. Please let me know if someone has pans they're about to swap in to the same model or just knows the dimensions from a drawing some place and provide dimensions if you could. I couldn't find any numbers anywhere. Thanks
Wasn't sure if I was supposed to put in exterior/interior appearance section, let me know. |
1 Attachment(s)
This was the first Google result... I believe all the measurements are in the FSM no?
thanks a bunch, i ended up just ordering the pans from MSA because they dropped in price since the last time i looked and the shop doing the bodywork said theyd give a discount on labor if i brought them precut pans instead of sheet metal. Regardless thanks for finding it. I had found one similar to that before, but when I clicked on it at work, the work internet blocked the image.
