ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   L28 into 73 240Z (fuel tank question) (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/l28-into-73-240z-fuel-tank-question-4431/)
aa1b Nov 29, 2002 07:30 PM
I found out that I will need to install a fuel return line for the EFI, will it be easier to install the 280Z tank or just modify my tank to accept a return line?
Any other tips on the fuel system- fuel pumps would be great!
Thanks in advance, kevin
zbobo Nov 29, 2002 10:25 PM
Re: L28 into 73 240Z (fuel tank question)
gotta have the fi tank. fuel line diameter is different, and therefore so are the outlet "tits" on the tank itself. so, to prevent fuel starvation you need to update the tank... here's the catch. you need one from a 75 or 76 since after that they redesigned the rearend just enough to make the later tanks incompatible. (punks.) i'm going through the same bull$#@! pitting a 280zx turbo engine in my 260. but it's worth it....you couldn't pay me enough to deal with frickin' carbs anymore.
74 260Z Almost Turbo
Tickets To Date: 0
aa1b Nov 30, 2002 06:06 AM
I guess I got lucky, my donor car happens to be a 76(NA) and the car it's going into is a 73. I guess I am more of a EFI person to! carbs are Bu!@# sh#@!
Will I need to run larger lines back to the tank?
Thanks,Kevin
zbobo Nov 30, 2002 12:00 PM
y'know, i don't have the tank yet, so i'm not sure.... i'm just going to base it on the inlet/outlets of the tank. if the "tit" is bigger, the hose should be too.
Tickets To Date: 0
stev240z Dec 1, 2002 08:04 PM
I ran an L28 w/ FI in my '71 for about 6 months w/ the stock links and an EFI pump at the tank---- stock tank too...
NO PROBLEMS whatsoever----
-Steve
http://hometown.aol.com/stev240z
zbobo Dec 2, 2002 10:57 AM
steve.... would the stock tank and lines work in a turbo car? he fuel pump i know has to change, but if i don't have to deal with dropping that tank again, i'd be loving life : )! you mentioned yours was a non-turbo, so would that make a difference?
Tickets To Date: 0
stev240z Dec 2, 2002 05:00 PM
I dont know about the OE tank and lines w/ a turbo, but I'd definetely try it before pulling the tank! if you have no problems then dont worry about it--- worst case it cuts out at high rpms--- you drive it a while and replace the tank when you get a chance--- know what i mean?
-Steve
L0ki Dec 2, 2002 05:01 PM
depends on your plan for the turbo if you are going to run standard boost and not drive it hard you should be ok but otherwise....
Rusty Datsun x 2
1x Bronx Grey 260Z 2+2 (Soon to be blue)
aa1b Dec 2, 2002 07:03 PM
Hey Steve,
Did you run a return line back to the tank with your EFI swap?
Also, did you use a charcoal canister?
Kevin
stev240z Dec 3, 2002 09:18 AM
I used the OE '71 return line as well as the supply line, and no I didn't use a charcoal canister.
-Steve
