idle issue
Old Feb 15, 2007 | 07:32 PM
skittle's Avatar
Taste My Rainbow
idle issue
ok got the new z tonight and its running wierd already.
When i replaced the #4 injector it has lots of power now. Now the issue is when its at idle the engine "burps" or "Sutters" sort of like a v-8. When I take off the #4 plug to the injector it goes away and idles smoothly. I don't want to run on 5 cylinders.
any ideas to why this is happening, and how to fix it?
Old Feb 15, 2007 | 07:36 PM
haha... ask the guy if he ever put an aftermarket cam in it... its porbably a nill chance but happened to my dad... he tried dickin around with the car for so long cause it sputtered around idle but rev'ed good, turns out previous owner put a cam in it. go figure? but if it drives great and just has a wierd idle could also be like the FPR
Old Feb 15, 2007 | 09:33 PM
skittle's Avatar
Taste My Rainbow
yeah new fpr though... hmmm
Old Feb 15, 2007 | 10:03 PM
how do you know... did you put it on? DID YOU! lol. see cause if its running good at WOT on all 6 but idles like crap on all 5... thats just a wierd issue.. timing?
Old Feb 16, 2007 | 06:53 AM
skittle's Avatar
Taste My Rainbow
no it idles on 6 wierd but on 5 its good...
Old Feb 16, 2007 | 07:51 AM
It might idle good, but the rpms should drop... so it's not "running better" just smoother. Pull your spark plugs & look @ the tips. See if they are all the same.
Old Feb 16, 2007 | 08:14 AM
naviathan's Avatar
Pull the spark plug on that cylinder and see if it's fouled.
EDIT: Actually just change that plug. If the old injector wasn't firing the plug is probably electrically fouled and you won't see it.
Old Feb 16, 2007 | 08:22 AM
skittle's Avatar
Taste My Rainbow
brand spank'n new nkg iridiums... (SP?)
Old Feb 16, 2007 | 08:32 AM
RodMoyes's Avatar
Doesn't post much...
Why did you waste your money on Iridiums???? They won't make ANY difference and will most likely not even work as well as the plain old stock NGK's. Using anything other than stock just doesn't work on these motors. Next time, save yor money.
Rod.
Old Feb 16, 2007 | 11:17 AM
yeah the platinum tips is all good... im gonna get some coler plugs though since im turbo'in an NA engine.
Old Feb 16, 2007 | 02:51 PM
skittle's Avatar
Taste My Rainbow
I Would Have Gotten The Cheaper Ones But They Did Not Have Any Instore So I Had To Get The Iridiums... I'll Try To Get Some Video Of It So You Can See What I Mean.
Old Feb 16, 2007 | 03:05 PM
skittle's Avatar
Taste My Rainbow
Can It Be A Flat Spot On The Cam That Could Be Causing This Issue?
Old Feb 16, 2007 | 10:08 PM
Prolly not.... check out the easy before jumping to the difficult.
Old Feb 18, 2007 | 01:04 PM
skittle's Avatar
Taste My Rainbow
yeah i hope its not that... at least i have a spare engine in case i do.
madkiwi
Jun 6, 2015 07:40 AM
Lupe
Sep 25, 2011 09:50 PM
RaTT92
Dec 10, 2010 12:17 PM
kiboy6
Dec 13, 2008 01:53 AM
fufaso
Nov 4, 2007 10:02 PM
