ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   idle issue (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/idle-issue-21832/)
skittle Feb 15, 2007 07:32 PM
idle issue
ok got the new z tonight and its running wierd already.
When i replaced the #4 injector it has lots of power now. Now the issue is when its at idle the engine "burps" or "Sutters" sort of like a v-8. When I take off the #4 plug to the injector it goes away and idles smoothly. I don't want to run on 5 cylinders.
any ideas to why this is happening, and how to fix it?
snwbrderphat540 Feb 15, 2007 07:36 PM
haha... ask the guy if he ever put an aftermarket cam in it... its porbably a nill chance but happened to my dad... he tried dickin around with the car for so long cause it sputtered around idle but rev'ed good, turns out previous owner put a cam in it. go figure? but if it drives great and just has a wierd idle could also be like the FPR
skittle Feb 15, 2007 09:33 PM
yeah new fpr though... hmmm
snwbrderphat540 Feb 15, 2007 10:03 PM
how do you know... did you put it on? DID YOU! lol. see cause if its running good at WOT on all 6 but idles like crap on all 5... thats just a wierd issue.. timing?
skittle Feb 16, 2007 06:53 AM
no it idles on 6 wierd but on 5 its good...
NismoPick Feb 16, 2007 07:51 AM
It might idle good, but the rpms should drop... so it's not "running better" just smoother. Pull your spark plugs & look @ the tips. See if they are all the same.
naviathan Feb 16, 2007 08:14 AM
Pull the spark plug on that cylinder and see if it's fouled.
EDIT: Actually just change that plug. If the old injector wasn't firing the plug is probably electrically fouled and you won't see it.
skittle Feb 16, 2007 08:22 AM
brand spank'n new nkg iridiums... (SP?)
RodMoyes Feb 16, 2007 08:32 AM
Why did you waste your money on Iridiums???? They won't make ANY difference and will most likely not even work as well as the plain old stock NGK's. Using anything other than stock just doesn't work on these motors. Next time, save yor money.
Rod.
snwbrderphat540 Feb 16, 2007 11:17 AM
yeah the platinum tips is all good... im gonna get some coler plugs though since im turbo'in an NA engine.
skittle Feb 16, 2007 02:51 PM
I Would Have Gotten The Cheaper Ones But They Did Not Have Any Instore So I Had To Get The Iridiums... I'll Try To Get Some Video Of It So You Can See What I Mean.
skittle Feb 16, 2007 03:05 PM
Can It Be A Flat Spot On The Cam That Could Be Causing This Issue?
NismoPick Feb 16, 2007 10:08 PM
Prolly not.... check out the easy before jumping to the difficult.
skittle Feb 18, 2007 01:04 PM
yeah i hope its not that... at least i have a spare engine in case i do.
