hey
i keep getting this.
Post rejected because of a score of: 60 Rejection set to: 30. |
and im trying to say this.
can i use rims with a +40 offset on my 78 280? or will they stick out? i dont really like any of the "280 specific" rims. but they all have +0 offset. and i like some of the sciion xb rims, and they have +40 offset rims, and i just want to know if theyll work. thanks. and sorry for that thing above this, i dont know why i keep getting that |
Originally Posted by jumpman2334
(Post 269726)
If you want to use + offset wheels, you need wheel adapters: http://www.modern-motorsports.com/ca...hp?cPath=57_56 Welcome to ZDriver! :006: |
It means the mounting face of the wheel is 40mm past center. The wheel will hit the springs. You would need adaptors 40mm thick just to get even again. If the wheels are wider you will have to add half to inside and outside. MSA sells some nice wheels that don't require adaptors or spacers.
thanks for the heads up.
and i cant just use some spacers that are 40mm thick? i have to buy some 215 dollar adaptors? i know it changes the spacing from 4x114.3 to 4x100. but most of the wheels i was looking at have both the 4x114.3 and 4x100 bolts pattern on it already. |
Originally Posted by theramz
(Post 269743)
(Post 269770)
and i cant just use some spacers that are 40mm thick? i have to buy some 215 dollar adaptors? i know it changes the spacing from 4x114.3 to 4x100. but most of the wheels i was looking at have both the 4x114.3 and 4x100 bolts pattern on it already. http://cgi.ebay.com/ebaymotors/15-8-...Q5fAccessories |
(Post 269770)
(Post 269790)
ive looked there before, as many rims are there, they dont seem to have that much of a selection
Like Theramz said... just gotta shop around. |
Yeah those are real nice but thefront bearing cap showing through looks cheap.
I made my own +25mm spacers and got like new 17"s with tires for $500. Next car I will make the 5 lug conversion and then I will be able to get any dia or width I want. |
You can get those same exact sportmax wheels for like $250 less on ebay.
http://cgi.ebay.com/ebaymotors/16x8-...#ht_2338wt_773 |
(Post 269810)
For me, I don't trust spacers at 100+ mph. Also I think the four extra holes look cheesey. There is a guy on eBay selling 16" wheels that will fit our cars without spacers and they look really nice for under $300. Go here-
(Post 269813)
You could, but then you'd have no threads left on the studs for the lugs to screw on. :D
thanks for all the input everyone. i just gotta look aroundd more i guess! |
