headers
Old Oct 22, 2007 | 07:28 PM
tonsoffun300zx's Avatar
West Coast!
headers
ok so I've been looking and reading (finally i know) but im still having problems figuring out what the difference is between a stock manifold and headers any advice cause im getting a better exhaust and want to know if i should buy headers or not
Old Oct 22, 2007 | 08:48 PM
Did you read through our "HEADERS EXPLAINED" thread ( https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/headers-explained-part-1-a-17672/ )? It really does explain a lot... along w/ other mods, they help the motor breathe / flow better than the stock cast iron manifold.
Stock exhaust manifold:
Header:
Old Oct 22, 2007 | 11:24 PM
West Coast!
yes i did read but what i don't get is that it is still six holes going from the engine to the exhaust and if it's worth it on an s30
Old Oct 22, 2007 | 11:31 PM
entropy31's Avatar
The Cake Is A Lie!
headers make the cylinders all equidistant from the exhaust exit point, and flow better than the stock manifold.
Old Oct 22, 2007 | 11:34 PM
West Coast!
so yes i should get headers or can i put them on later if i want to after i put my new exhaust on?
Old Oct 23, 2007 | 12:32 AM
chinesekid's Avatar
you can put it on later, but it would be easier to do it all at once
Old Oct 23, 2007 | 06:36 AM
Six holes???? Those are the exhaust ports for each cylinder... it's a 6 cylinder motor... 1 intake 1 exhaust for each cylinder... 6 x 1 = 6. And it doesn't matter if it's an S30 or S130... what matters is what you are doing to the actual motor.
Old Oct 23, 2007 | 11:58 AM
theramz's Avatar
I have a present for you...
I put a 6-2-1 header from MSA on my 240 and it made a big difference in performance and makes a nice sound. I added a SuperTrap muffler on it because you can adjust the back pressure by adding or removing the baffle discs. You can remove all of them for straight through flow for top end but it's really loud. 2 1/2 '' all the way back. The header comes very close to #3 intake so plan on using header wrap on all the tubes at least 12" long.
Old Oct 23, 2007 | 12:18 PM
theramz's Avatar
Oh yeah, lose the stock air cleaner and get the bonnet type x 2. Now you can back out the thumb screws on the bottom of the carbs about 1/4 turn. More air, more fuel!
theramz
Sep 29, 2004 11:19 PM
cm3
Apr 5, 2004 10:56 AM
rupert42
Mar 24, 2004 08:56 PM
chrissyp183
Oct 31, 2003 12:54 AM
superb60ce
Jun 4, 2001 10:37 PM
