Fuel pump
What fuel pump are you turbo guys using? I've got a stock turbo pump right now, which will get me started and running I hope, but I feel the need for speed allready. :) Whats a good option to support up to 350-400hp?
Re: Fuel pump
im not sure what most people use but i would suggest looking at a NOS made fuel pump, or something that people would use on American hotrods. i think anything that keeps ur fuel at like 7psi + will work.
eurozx.org |
Re: Fuel pump
Uhhh. I need at least 36psi. (I believe that is what the stock turbo engine runs at) I would very much like to find a pump that puts out 50psi+ at a descent flow rate, so that if I want to run different styles of injectors I have the pump to support them. I've been look at the bosch high flow pumps, but they are pricy.
Re: Fuel pump
Hey dood, whatsup. Okay heres what i selected on the fuel pump. I wouldnt reccomend it either. It is an ESSEX unit. About the size of a fosters beer can. Its a great pump but its so monsterous that its hard to find a place to put it. I do belive james thurgard (sp?) is running a pierburg pump from corky bell. Might want to check into that. One thing, dude try to find the quietest one you can! BZZZZZZZZZ all the time would be annoying.
Evan Well while i have it apart i might as well........ |
Re: Fuel pump
I am also running the Pierburg and so is the 11-sec 240 turbo I posted a while back. It is not totally silent, after all we are almost sitting on top of it, but it is quiet. It comes encased in a pre-formed rubber shield.
Scottie Scottie's GNZ |
