Fuel problem?
Old 08-09-2018, 02:01 PM
Spikzsta's Avatar
Fuel problem?
I am not a pro mechanic, I started on this project z ‘75 280z fuel injected. I changed all the gaskets and realized I needed new fuel injectors. I pulled them and changed them. I didnt relieve the pressure by disconnecting the line and letting the pump pump it out. I leaked some fuel and relieved the pressure that way. I replaced everything and put the car back together when i went to turn it on it wouldnt turn on.
It cranks and if i give it gas it tries to turn on but wont stay on. I think i have spark. When i have the key in the on position i can hear the fuel pump working. My gas tank currently has under a quarter of gas. And before i change all the spark plugs and wires how can i make sure if its the gas pressure or if it isnt getting enough gas. I changed the fuel filter too. What should i do to run diagnostics? Thank you!
Spikzsta is offline
Old 08-21-2018, 06:15 AM
I have a present for you...
theramz's Avatar
You need to download the factory service manual. Check the fuel pressure and the AFM
theramz is offline
280z78
01-14-2015 04:08 AM
ThatDude114
06-15-2014 08:43 AM
sdkid123
06-05-2011 03:26 PM
country
03-03-2011 04:54 AM
justinmy300z
16
02-04-2006 12:20 PM
Quick Reply: Fuel problem?
