Engine stalls when press throttle
Guest
Posts: n/a
I am having great problems with my 79 280zx. It will sit and idle fine all day but most times when you press the peddle the engine shutters and almost stalls. It also acts like it is backfiring through the intake. I recently replaced the fuel pump. I don't even know what to start checking with the fuel injection system. Any ideas would be greatly appreciated.
Thank You
Thank You
Guest
Posts: n/a
Re: Engine stalls when press throttle
I don't know too much about fuel injection cause I have a 70' 240. I think it sounds like you need more air. I think you can disconect the air flow sensor from the throttle body, but leave the wiring connected, then floor it and see what that does. It might be that you need a new one, or you just need a new air filter. On a carbed Z when that happens your air to fuel mixture is wrong or the plugs are dirty or bad. Your timing might have something to do with it. LIke I said I don't know injection but that seems logical to me.
Guest
Posts: n/a
It could be your throttle position switch, does it kinda bog down a bunch before it revs up, like it tried to choke and then hesitates? Well anyway, if it's the TPS, you have to adjust it, I"m not entirely sure of the procedure in a 280, but for a 300 you disconnect the plug and check the top 2 tines for continuity, and rotate the switch until it contacts... I'm sure someone can explain it better than that, but it's in the Haynes guide, and you can try that, costs no money to adjust the switch, if not that, then you can keep looking...
The Beast is back and badder than ever!
dude
CANADA
-40 all month now i cant possibly start it if it had a freaken best cold start valve in the world
ill wait till it gets above 5
i can start it nice when its round 0
keep it realZ
1981 280zx T-Top
Saskatoon, SK, Canada
CANADA
keep it realZ
1981 280zx T-Top
Guest
Posts: n/a
IF YOU LIVE IN ANY REGION THAT DOES NOT GET BELOW 71 F. OR 22 C. THAN IT DOESN'T OPERATE BUT THERE ARN'T MANLY AREAS IN CA. THAT THAT HAPENS.
AND IF IT ISN'T WORKING THAN YOU HAVE A MIXTURE PROPLEM.
ONEFSTZ
ONEFSTZ
SINCE I DRIVE IT IN SUMMER I DUN GIVE A CRAP CUZ IT WORKS AWSOME IN SUMMER I MEAN MY MOMS 96 STRATUS BARELY STAARTS IN WINTER(no it starts but like pretty hard on remote start)
keep it realZ
1981 280zx T-Top
keep it realZ
1981 280zx T-Top
venom8343
Oct 15, 2006 12:43 AM
