bumblezee |
06-04-2003 01:31 PM |
you take the plastic cover off the afm. under it is a what looks like a huge black gear. there is a screw and a piece of metal holding it on the side. hold the wheel, and loosen the screw, turn the when clockwise one tooth, tighten the screw back down. that gear looking thing in the afm is a potentimeter. a spring is behind it that closes the flapper. the tighter you turn the potentimeter (gear looking wheel) the leaner your car will run at idle. the looser (counter-clockwise) you turn the wheel the richer you run at idle. just hold the gear while loosening the screw because if you dont.. the gear will unwind itself and you will have a nice time re-adjusting it all.
