electronic point conversion...help!
Old Aug 7, 2003 | 11:47 AM
zpeedracer25's Avatar
Go to Zhome.com Then go to the their technical library. You can find an article there on how to wire in the distributor from a 280ZX NA.
Old Aug 7, 2003 | 11:49 AM
here's the name of the article:
"How To Wire The ZX Distributor and Ignition Module; or the Pertronix Ignition, into your 70-72 OEM Wiring"
Old Aug 7, 2003 | 02:15 PM
Cheapest way to go would be to buy a distributor off of a 280ZX from the junkyard....too bad for you I sold my spare last weekend...doh!
Old Aug 8, 2003 | 07:25 AM
Re: electronic point conversion...help!
Originally posted by Airpilot16
I should either a.buy a new distributor, or b. get an electronic point conversion kit, and install that. He recommended the electronic kit because I wouldn't have to adjust the points, and the car would have higher performance
I think you're missing the point. I don't want to get a new distributor/a different one, all I want is the electric point conversion kit. All I wanted was the Pertronix Ignition set, and I'm wondering what info I would need to make sure that my car is compatible with it.
Thought I had your point nailed down, but guess not.
If your distributor rod is worn as your shop stated, you have no choice other then to rebuild your distributor or replace it. Installing an electronic pickup coil doesn't get you around this. Whether you replace it with the stock points type or go to electronic pickup coil is up to you. Switching to electronic pickup coil run distributor is the best option and buying a used distributor from junked 280ZX is still the cheapest way.
Old Aug 8, 2003 | 07:59 AM
No problem!
Sorry if the previous reply may have sounded a little harsh. Its been a long week between a horrible boss and my not getting any sleep trying to help my wife get hers.....kids due next week!
zdadgeezer
Apr 2, 2014 05:08 AM
thxone
Aug 11, 2006 02:54 PM
DarrellBuddy321
Dec 10, 2004 11:01 AM
MetalTear17
Aug 22, 2004 09:26 AM
cerealkilla
Nov 8, 2003 06:27 PM
