egr valve
Old Dec 27, 2014 | 06:32 PM
280z dude's Avatar
egr valve
hi everyone... have my 80 280zx .. was wondering about eliminating the egr valve....pro's,,,,cons????let me know.....thanks...
Old Dec 27, 2014 | 09:53 PM
Zdon's Avatar
Egr valve elimination pros and con
I like the word con because if you're in California and get caught without an egr valve you can be con-victed. It depends on the where you live and their smog laws. However a car without an egr valve gains at least 5-10hp but you'll have to eliminate the catalitic converter which will also give you more hp. Hope that helps.
Old Dec 28, 2014 | 08:34 AM
280z dude's Avatar
thanks zdon for the reply....just wondering why I would have to take the cat out if I eliminate the egr??? now I see im in the wrong form since I have a 80 280zx..im sure the same applies though... thanks
Old Dec 29, 2014 | 08:32 AM
That is far from correct. The EGR isn't always active or passive. All it does is recirc a small amount of exhaust. Removing the EGR does not increase HP, nor does it also require removing the cat.
BUT if your car does have to be smog checked, they will likely ding you for not having an EGR which may or may not fail you.
Old Dec 29, 2014 | 03:29 PM
Zdon's Avatar
Knowledge is a wonderful thing and everyone has some of it. Straight through exhaust piping does increase flow therefore increasing power and engine performance with fresh air fuel mixture tuning. It takes several engineers with varying skills to build a rocket and yes even a car. Happy new year Z'ers.
Old Dec 30, 2014 | 11:50 AM
Alright... trying not to go overboard on this one...
USUALLY, yes.
As I previously stated, the EGR isn't always active. Just throwing out a random " +5-10hp " statement like that doesn't mean it's true. You should learn how and when an EGR works before assuming that removing it magically adds 10hp (which is an extreme stretch no matter what).
And again, removing the EGR and removing the cat are two unrelated things. You do not "have" to remove the cat when you remove the EGR... again the EGR isn't always functioning.
Arg... just open the FSM sometime.
Old Jan 3, 2015 | 07:18 PM
280z dude's Avatar
thanks.... everyone for the replys.. not looking for any hp on this one....im doing the head gasket and also looking at cleaning up the intake a little.. just don't like to take things off that may effect other things.......
Old Jan 6, 2015 | 01:27 PM
Click: https://www.zdriver.com/forums/240z-...anifold-19937/
Old Feb 8, 2015 | 08:16 AM
k5ride's Avatar
The egr does not function under acceleration so it does not have an impact on hp. It does however lower combustion temp. Which in turn can lower operating temp. Do a little research before deciding to remove.
dubber707
Jan 25, 2012 10:39 PM
Ryan280
Mar 9, 2007 08:33 PM
haktmal
Apr 20, 2003 06:59 PM
