DSM tuner interested
Old Oct 5, 2002 | 08:19 PM
Spudz's Avatar
Re: DSM tuner interested
First if you want to go fast use a 240Z body. Much lighter then
the ZX and its easier to get performance suspension parts.
The ZX shared the L28 motor with the 280Z . The ZX had a
different casting and some refinements over the earlier L28,
L26, and L24 (240Z ) engine. A boosted and I/C'd L6 can easily put out 300RWHP. If your going to do something like
that then find a Turbo 280ZX and get the drive train from it.
BTW the ZX would way around what the last generation
DSM without the aid of all wheel drive.
Mike
Old Oct 7, 2002 | 09:18 AM
lifegrddude's Avatar
Externally Wastegated
Well, I'm working on my ZXT, and the popular upgrade for the turbo is either a t3/t4 or a t3/t04B. I've got the t04b turbo in, but no intercooler yet. I'm saving up to use a Spearco intercooler. Before the turbo, the car ran a 14.72 with a K&N intake, and an HKS exhaust. I have yet to run it again because I want to have the i/c in before I test it.
The stock turbo is a T3 non-water cooled unit with a .63 a/r. Not bad for a stock unit and easily out flows similar turbos such as the SVO Mustang's and the Thunderbird's. Those turbos were a T3 wth a .48 a/r... only good for budget small displacement turbos like 1.6L Hondas, 4AG's, etc.
On average, from what I've been told from other turbo people, the stock bottom end is good to ~300hp. The head gasket is usually something that goes after you hit 12 psi or so, many upgrade to the HKS one or O ring.The only mechanical weak spot I've heard of the Z is the water pump... Keep an out on that, also change the fuel lines as 3 other people who have Z's and me have had our fuel lines burst while driving. 2 cars caught fire (but were put out). I looked at zcar.com and apparently it happened to several other people as well. Anyway, this is long. Good luck and happy tuning.
82ZXT
71 510 autocross & 71 510 daily driver
Old Oct 7, 2002 | 09:39 AM
Oh yeah one more thing. Keep an eye on your exhaust manifold bolts, specifically by the 5th and 6th cylinder... They tend to get loose a little and if that happens even for a couple of drives, you'll get a lovely exhaust leak and that gasket is a pain to change. The turbo bolts to the exhaust manifold are another item to check every so often too. They are a part of the reason why many turbo owners complain about a lack of consistency of power delivery. If only they'd look! If those bolts are loose, you have a lot of lag and the power delivery isn't linear at all. I'd check every other month or so.
82ZXT
Torque Solution
Southeast Region
Dec 27, 2011 04:57 AM
islandtuner242
May 29, 2010 06:38 PM
dustin_ra
Oct 31, 2007 10:24 AM
agnerjsantiago
Dec 10, 2002 06:02 PM
