Compression Ratio?
Would any of you happen to know the compression ratio of a standard deck heighth '83 280zx block with standard size flat top pistons, and an E31 head strapped on it, no metal removed from the underside of this either.
Re: Compression Ratio?
L28 block
L28 rods (130.3mm) E31 head (42.4cc) Std gasket (7.6cc) L28 crank (79.0mm) L28 flattops (86.0mm) =10.2:1 Ben Adelaide, South Australia. |
