Coil Overs?
Old May 28, 2002 | 05:51 PM
auxilary's Avatar
the Dude
Re: Coil Overs?
i am running GC coilovers. what would you like to know?
you can get them from www.strictlyz.com, they're running a special on 240z coilovers for 359 for a set of 4 ($40 cheaper than from ground-control.com), or ground-control.com has a combo with tokiko illuminas for something like 850.
www.outlaw-brakes.com also carries coilovers, and so does www.modern-motorsports.com
Old May 29, 2002 | 10:04 AM
auxilary's Avatar
the Dude
Re: Coil Overs?
you can lower your car quite a bit, but make sure you have camber plates to compensate for the immense negative camber you'll get from the drop. you don't really need to cut the tower if you have 5" sleeves = you need to grind off the spring perch and weld the ring that the sleeve sits on. Instructions are included with the coilovers, and look in the attachment to this post with a scan of one of the instruction sheets. the other one's a lot more detailed and graphical.
Old May 29, 2002 | 12:06 PM
auxilary's Avatar
the Dude
Re: Coil Overs?
no, i didn't. they're not required, unless you want hte adjustability for track.
Mitchf253
Sep 27, 2012 12:08 PM
KuRupT_Z31
Feb 23, 2011 11:32 AM
domsgarage
23
May 5, 2008 09:15 PM
madhatter
Apr 30, 2003 04:01 AM
Phillip240
Oct 22, 2001 05:57 PM
