electronic point conversion...help!
Guest
Posts: n/a
hey guys, I took my Z down to the auto shop today, to get the carburators synched. The technician that synched the carbs told me that the distributor rod is pretty much worn, and that I should either a.buy a new distributor, or b. get an electronic point conversion kit, and install that. He recommended the electronic kit because I wouldn't have to adjust the points, and the car would have higher performance. I have no idea who makes these kits, so if anyone knows who does, please let me know! (preferably a company that carries them for my 72 Z)
Guest
Posts: n/a
I think you're missing the point. I don't want to get a new distributor/a different one, all I want is the electric point conversion kit. All I wanted was the Pertronix Ignition set, and I'm wondering what info I would need to make sure that my car is compatible with it.
Re: electronic point conversion...help!
If your distributor rod is worn as your shop stated, you have no choice other then to rebuild your distributor or replace it. Installing an electronic pickup coil doesn't get you around this. Whether you replace it with the stock points type or go to electronic pickup coil is up to you. Switching to electronic pickup coil run distributor is the best option and buying a used distributor from junked 280ZX is still the cheapest way.
Guest
Posts: n/a
oh, now I get what you were saying! I thought you meant that I had to go buy a distributor and point kit to make it work, not one or the other. I asked the tech about the worn rod, and he said that if I were to install the conversion kit, it wouldn't wear the rod down anymore, and that I'd be fine. Thanks for your help!
No problem!
Sorry if the previous reply may have sounded a little harsh. Its been a long week between a horrible boss and my not getting any sleep trying to help my wife get hers.....kids due next week!
zdadgeezer
04-02-2014 05:08 AM
