camshaft problem
I bought a cam from motorsport (part# 10-2003) and I put about 6000 miles on it. after pulling off the valve cover to inspect it was very worn. I think it wasn't geting enough oil. Do I need to block off the cam oiler with the block off plates or do I need a new cam oiler?
thanks |
All of the performance cams that MSA sells have the internal oiling system. You definetly need to block off the spray bar or there won't be enough oil pressure to lubricate the cam.
