cam.
Old Jan 21, 2007 | 01:05 PM
ThermalWake's Avatar
cam.
im looking to upgrade my cam. i dont want anything too radical, but i do want more pep but not completely kill my gas milage.. any suggestions on about the lift and duration or stage of cam i should go with.?
Old Jan 21, 2007 | 02:43 PM
MSA cam stage I: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2001
MSA cam stage II: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2002
MSA cam stage III: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2003
MSA cam stage IV: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2004
MSA cam stage V: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2005
MSA cam stage VI: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2006
Info about stock Z cams:
http://www.geocities.com/bruskiz/ZCamSpecs.htm
If you don't want anything radiacal... go w/ a mild cam.
Old Jan 21, 2007 | 04:06 PM
id go with the one or 2 for your wants and needs if you just want a little get uo and go. mine is a bit higher than the 2, more towards the 3, and it isnt too bad, still quite streetable
Old Jan 21, 2007 | 08:22 PM
do i have to replace all valvetrain as well?
Old Jan 21, 2007 | 08:27 PM
BigBirdsZ's Avatar
i want 2 port my head an i think the stage III will be wat i will be going with after the port sounds good right
Old Jan 21, 2007 | 08:57 PM
Only if you want to keep your warranty & prevent damage to your new cam:
Originally Posted by MSA
Note: Cam is ground on a new billet. Warranty on cam shaft requires use of new rocker arms, proper springs, proper lash pads, and proper professional installation.
When you use your already worn rocker arms, they can transfer their wear pattern onto your cam... if there are any impropper wear patterns, or defects in your rockers, your new cam will then receive the same pattern.
Also... depending on which cam you choose, you might need stiffer springs.
Old Jan 21, 2007 | 08:58 PM
Sorry wha? None of that made sense.
Old Jan 21, 2007 | 09:03 PM
BigBirdsZ's Avatar
i going to port and polish my head, and i want to go with the stage III cam, this cam would go good with a lite port right?
Old Jan 21, 2007 | 09:09 PM
Yeah, you deffinately want more air w/ the stage III. You're going to port the intake to match the head right?
Old Jan 21, 2007 | 11:38 PM
linluv84's Avatar
I had the 274 duration cam (stage 2?) and it was pretty good. It shifted the power band up by about 500 RPM on stock electronics, but Im sure it would have run much better on a properly tuned megasquirt. I threw it in with the old rockers without any problems, but your experience may vary...
Old Jan 22, 2007 | 11:21 AM
Sweets's Avatar
Usedta be Justin260z
If you are seriously going to port & polish your head, do not polish the intake side. If the surface is too smooth on the intake, the fuel will not atomize properly, and it will be slower than it was before. What I did with mine was ported the intake side like a bitch, and smoothed out the exhaust side. THen I ported my exhaust manifold to match that. I actualy roughed up the intake side a little. I didn't port the intake, just cleaned it up with sandpaper.
