Brake pedal - ZDriver.com
Brake pedal
Old 04-28-2018, 12:10 AM
Brake pedal
Hi guys. I have a 75 280z, my brake pedal takes muscle to sink and get my car to stop. I just changed the Brake Booster but it didnt soften up. How much is the BP supposed to sink in? Mine currently sinks about half way and i have to press it hard to complete a stop.
Spikzsta is offline
Old 05-01-2018, 08:16 AM
I'm not sure how far my brake pedal sinks. If you disconnect the vacuum hose to the brake booster and then cap or pinch the hose shut, does your brake pedal force change?
Mandrake is offline
Old 05-02-2018, 08:55 AM
Does it feel the same as before you replaced the booster? It could be a leak in the vacuum line or a bad check valve. Is there a change in the engine speed? Do you hear any hissing noise around the vacuum line?
Steve260Z74 is offline
Old 05-02-2018, 01:51 PM
i will double check it today. Thank you!
Spikzsta is offline
Old 05-02-2018, 01:53 PM
no change in the Engine speed, but i will be checking the vacuum. The brake pedal became a bit easier but it was still difficult to press it only goes down about half way.
Spikzsta is offline
Old 10-25-2018, 11:46 AM
I had a very similar issue on my 240z, took a lot of leg muscle to actual stopping power. I had bled the brakes (again), changed the front pads (again), replaced rear shoes, had rear drums turned. Tested the booster to make sure it was holding vacuum and it was. Finally, bled the master cylinder (front and back)... there was air in the line. I had had someone replace it maybe 3 years ago and didn't realize that was the problem and they hadn't properly bled all the air out. YMMV
amycyclenut is offline
SunnyD72
11-18-2015 11:11 PM
Darius Simmons
06-27-2014 11:08 PM
the_journeyman
10-19-2011 02:49 PM
jessezx
09-26-2009 04:20 PM
ZChief
05-30-2006 10:51 AM
Quick Reply: Brake pedal
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
