Anybody have a fumeless Z
Before i start to restore my 240, has anybody totally resolved the issue of exhaust and gas fumes entering the cockpit.
And how did you fix both fumes ? [img]/w3timages/icons/tongue.gif[/img] |
Re: Anybody have a fumeless Z
you got a exaust tip that dose 2 things. Its also a wheelie bar! =P
1974 junkyard 260Z 100% Junk Will be restored to a new car by next year. |
That sort of pipe suites that reject 2+2 but i need to know has anyone solved it on a real z.
I've solved my fume problem. First off, get your motor running right so there isn't an excess of fumes. Then pull out all of the plastic stuff in the back. Go to the store and buy two tubes of silicone caulk and put it all back there covering any seam to the outside. Spread it around the tail lights and where your gas tank vent lines go through the body. Then replace your hatch rubber and you will be good to go.
-jeremy- |
replace the tail light seals ... the two big rubber bungs on under the bumper make sure the hatch seal is good and put all the bungs in the bottom of the hatch
