alternator upgrade
i had posted this question earlier, but have not heard back from anyone at ideal z as of yet. has anyone upgraded a 73 or older z to an internally regulated alternator??
Re: alternator upgrade
I'm looking at this swap too now, but the link you posted doesn't really have any info on the swap itself, just the size of the alternator. Anyone actually done this swap and written up any sort of tech article? Or able to simply post a general outline here?
Hiya all,
You know what come to think of it I don't think anyone has done a swap article huh? I believe its pretty simple I did a IR swap on my 510 with a280Z IR alternator, a 280ZX one should work as well correct? well here's a linke for the 510 one the alternator should bolt up I think hard part is getting the wiring correct. This link might help a little.. I hope http://dimequarterly.tierranet.com/a...ech_iralt.html |
I heard that a place called Z Specialties in Seattle had some
internally regulated, high output alternators that bolted right onto any Z car or 510. You can check out there website at www.zspecialties.com There phone number is 206-363-3577 James |
friend of mine [auto electrical specialist!] will be doing the ir alternator conversion for me, once completed i will submit an article so anyone else who wants to can do the same. plans include an output upgrade to a 90amp alternator, for less than $100!
I've done it. I put in a 79zx alternator in my 240z. Followed the instruction on ideal-z. Now my car wont shut off when you take the key out. I have to turn the key very slowly until just before the off position, then it will turn off. But if i turn it to fast it will stay on. Its pretty dang wierd. If i take the modified regulator connector off, then everything works properly except it wont charge. I think they got the instructions wrong on which wires to short.
If you are trying to bypass the mechanical voltage regulator why note use a solid state unit i.e. Well VR728 for about $30 Canadian.
I found out how to make the zx alternator work in a 240z. You have to short those wires as described on zhome.com, but you also have to install a diode. Heres the link.
http://www.zcar.com/forums/read.php?...69269&t=169269 I followed these instructions and the car now functions perfectly. Ejnoy. |
