almost done
Old Sep 9, 2006 | 01:55 PM
ThermalWake's Avatar
almost done
well, the 78 is almost completely painted, (primed) its gettin there weekend by weekend. about 3 more cans and ill be done, sanding down the rust is a bitch, aspecially by hand. but im gettin there ill have pics up soon
Old Sep 9, 2006 | 08:35 PM
theramz's Avatar
I have a present for you...
Oops!
Ask who ever is going to paint the color about spray can primer. It is not a good base. Spray can paint contains propellants, usually propane that don't adhere well to metal. Your paint will peal off sooner or later. A painter will probably tell you to sand it all off. Don't shoot the messenger!
Old Sep 9, 2006 | 09:28 PM
im just doing it to get rid of the rust for now its totally temporary, when i get deployed to iraq, its going to my friends shop in amarillo texas, its getting some body work done, front air dam side skirts, rear skirt, keyless entry, take off the handles and key holes, redo the interior, new custom dash. new seats and everything. then the l28 is coming out, im dropping a LS7 C5R block. 427 long block forged from the ground up, 639,639 lift cam 112 114 duration, LS7 heads ported and polished, coated long tube with 1 7/8 inch primarys, forged turbo 350 tranny, 9 inch rear end, im going to have the rear wheel buckets cut, so i can tuck 345's in it, a 4000 stall and slap stick. chassis supports k member new a arms, a chute, and hopbars. im goin for a record. his friend in texas put 668/673 on just motor alone. and im also going a 350 duel stage, menthonal injected. its going to be painted a rusty/burnt/sunset orange. with a small cowl inducted hood.
Old Sep 9, 2006 | 09:50 PM
FYI... not all rattle can primer is crappy. Make sure it's "Self Etching" metal/auto body primer & you will be okay.
Another FYI... priming over rust WON'T stop the rust... even if you have ground out the rust to where it doesn't LOOK orange. Rust will come back unless removed completely.
Old Sep 9, 2006 | 09:55 PM
do remove it completly i sand until all i see is bare metal.
Old Sep 9, 2006 | 10:08 PM
You can get rid of surface rust by sanding... but if there are rust pits left, it's not gone.
Old Sep 9, 2006 | 10:16 PM
apollo's Avatar
Pro Pumpkin Carver
There are a few chemical solutions to pitted rust areas that turns the rust in to a sandable product and prevents it from coming back. . .Zero-Rust? i cant remember it now but i'll come to me
Old Sep 9, 2006 | 10:30 PM
skittle's Avatar
Taste My Rainbow
wow an ls7 huh??? from the new Z06?
Old Sep 9, 2006 | 10:44 PM
yeah, a genuine C5R naked block is like 7k im not gana get a genuine C5R im getting the LS7 427 long block. the block with LS7 heads is like 4k. prolly gana go with a 639/639 112/114 cam, coated longtube 1 7/8 inch primary headers, port n polish my heads ballance the internals, and a direct port 350 duel stage. a forged turbo 350 tranny with a 4000 stall and slap stick, and a 9 inch rear end.
