ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   Air Flow Meter (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/air-flow-meter-2398/)
aznsensation Jun 27, 2002 04:43 PM
Air Flow Meter
Do You Have To Run The AFM or can i just run a pipe then the intake filter. will this give me more airflow and power?
Draven Jun 27, 2002 04:50 PM
Re: Air Flow Meter
Yes you do need the AFM, or your car won't be able to start. That is from my experience, but unless anyone else has tried something else. you really do need it.
"It can't rain all the time"
aznsensation Jun 27, 2002 08:31 PM
Re: Air Flow Meter
thanks for your reply
Ben Jun 28, 2002 06:20 AM
Re: Air Flow Meter
The AFM is used as the primary reference for metering the fuel injection system. Unless you switch to an aftermarket system that can use a MAP sensor, the AFM is required.
Ben
Adelaide
Sth Australia
IZCC#1902
240Z L31ETT
L28ET MR30 Skyline
FJ20DET DR30 Skyline RS-X
