78z only starts sometimes
Old Oct 9, 2011 | 03:21 PM
1995buick's Avatar
Hi there,
I recently purchased a 78 280z. The fuel pump does not want to run when the car is being turned over but when wired directly to the battery it will pump gas. It will start once and a while and purr like a kitten but its very anoyying when the pump decides not to run. Any help would be great.
thank you
Old Oct 9, 2011 | 04:39 PM
Welcome to ZDriver!
Start by checking (replacing) the fuel pump relay and wiring / connections. Also, download the FSM at www.xenons30.com/reference
Old Oct 9, 2011 | 05:11 PM
Nismopu's Avatar
The AFM activates the fuel pump on these cars so, I would check the connection on the afm itself. It helped me get my 76 running some years back.
Old Oct 10, 2011 | 02:03 PM
theramz's Avatar
I have a present for you...
On the '78 cars the fuel pump is wired through the oil pressure switch not the AFM. Check your wiring at the oil pressure sender switch, it could be bad.
Old Oct 10, 2011 | 02:08 PM
Nismopu's Avatar
No ****? Pretty cool, didnt know that.
BozZ
Nov 13, 2012 03:10 PM
chaldeman
Oct 25, 2007 09:00 PM
Mtnangie
16
Aug 6, 2007 10:03 PM
skittle
Dec 11, 2006 06:48 PM
phrozen209
Jul 11, 2005 11:01 AM
