78z engine question
I just ran a compression check on a junkyard motor in a 280z. The compression was 160 on the low end and 175 on the high. It has the N47 head. Would this be a good one to swap into a 240z?
Re: 78z engine question
i would most definetly say yes. but are you going to stay with carbs or go to efi. if so you know you need much more. good luck and keep us posted james
watch out here comes my Z V8 powered and ready to roar |
I would swap on my Ztherapy SU's. The thing is that I thought the 78 z's had dished pistons. I thought dished piston motors had compression readings in the 140's not 180's.
Can anyone clear the air? |
